Results 1 to 3 of 3
Thread: Question?
    Jun 2009
    Tunkhannock,Pa
    904
    Question?
    Do any of you guys know anything about belt deflection? I have an 06 arctic cat 650 V2 and chews the top of belt right off. I read in the manual that if the belt deflection is off the belt will slack up to high, and I imagine that what wrong with mine. It also says you have to adjust it with shims behind the drive pulley. I never monkeyed with anything like that and was wondering if anyone on here could give me some insight. Thanks
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Sep 2007
    100mi west of Chicago
    3,582
    I've never had to do this on my sleds but I don't think it would be too hard. You can get the service manual here, but it's huge. Right-click, save target as:
    http://www.mymowerparts.com/pdf/Arct...ce__manual.pdf
    Rob
    Mar 2005
    overton, PA
    5,257
    you shim your moveable sheath on the secondary to close it slightly it tightens up and takes a little of the play out bring iut on out and well do it up.
