Results 1 to 15 of 15
Thread: ATC200 Won't start and has no spark...Neutral and reverse lights on.
    Saskatchewan
    6
    Hi I just got an 84 ATC200ES. it used to run great and then about a year ago just quit. My father inlaw didn't want to put any money into it so i got it. Here is the problem.
    -won't start, spark or do anything when pressing start button or pull starting it.
    -got a used CDI box today and still nothing
    -tested ignition coil. tested OK
    -Wierd thing is when i hook up the battery the neutral and reverse lights are lit up and it is not in reverse. the headlight also works.
    -kill switch is set to run.
    I am kind a new to trikes so any help would be great.
    Thanks,
    Jason
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    It sounds like maybe the reverse/neutral switch could have gone bad is now sending a false positive to the ignition. You might also have a problem with grounding. Check over your entire wiring harness and look for cuts/breaks/shorts/corrosion and check all your grounds for good, clean contact. You also might see what happens if you just unhook the reverse/neutral switch or what happens if you reverse the leads or what happens if you ground each lead one at a time.
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
    Texas
    137
    Quote Originally Posted by jfandrich View Post
    Thanks,
    Jason
    Yep, I second his comment about a bad reverse switch - if the reverse lights come on as soon as you hook up the battery, then there's a connection to ground being made somewhere in that circuit - whether it's the switch itself, a plug, or a wire that's shorted to the frame, you'll have to find out. The fact that both the neutral AND the reverse lights are on at the same time is a major clue - how can the trans be in both at the same time?
    Remember, if the bike is in gear (any gear) the ignition circuit is grounded out and you won't get any spark. Lights will work, starter will spin, but no spark.
    Saskatchewan
    6
    Thanks for the info. I will check out the wiring. The only thing is that the starter doesn't spin. nothing happens at all when the start button is pressed. I will let you know what I find.
    S. Florida
    26
    I had this on my BigRed 250es. Down by the shift lever there is a small plate that accepts the wires that light up those lights on the dash...one had simply come loose. Plugged it in and BAM fired right up!
    Ottawa Ontario
    5
    i have a 1984 200s and im having a similar problem as you are.
    i ordered a stator from the states about 2 weeks ago and should be in next monday or sometime next week. i'll let you know if there is any difference with the new stator.
    i have checked the ingnition coil, cdi, and wiring right down to the stator, soo i am assuming it is the stator that may be bad.
    Ottawa Ontario
    5
    hey, soo, i replaced the stator and man does mine run amazingly well!
    for sure it was the stator for mine.
    Saskatchewan
    6
    Quote Originally Posted by mad_on View Post
    So you had the reverse and neutral lights on at the same time...replaced the startor and everything is running great? I never thought of that. I checked the neutral/reverse switch and all the wiring and I can't seem to find the problem. I might need to try the startor.
    Apr 2009
    Saskatchewan
    119
    I noticed you said you replaced the cdi box. Are you sure it is the right one? I once tried the cdi box from a 200m on a 200es it plugs in fine but the reverse light came on for no reason and the bike wouldn't do anything. The correct cdi should be a number 969 I believe. Something to else you could make sure of. That is the only trike that took that cdi box and also a trx 200 quad.
    Saskatchewan
    6
    Hey Thanks Rugman. I just checked and the cdi box i picked up at the wrecker was a 968. I see you are from Saskatchewan. Do you know of any wreckers in Saskatchewan. The place I got the CDI box was by Borden. They want half the price of new on their parts and the selections not great. Just wondering if there are any other places out there.
    Apr 2009
    Saskatchewan
    119
    I have had no luck finding any good used parts in Saskatchewan. I have gotten some parts from the bikeboneyard in Montana a couple times. I bought a new cdi off ebay a few years ago but I see his price has went up since then its right around 150 with shipping but there is some used ones on there right now. I try to stay away from used parts when it comes to electrical parts like cdi because you can get the wrong one as you found out or somebody sells you one that doesn't work or it only works for a short period and then all of a sudden quits.I have had the aftermarket one on one of my bikes for three years with no problem. There is a member on here from Quebec that I have gotten a few really good used parts shipped to me he is good to deal with and sells really good used parts. I think his name is atc500 you could try him he might have one. I hope this info can maybe help you out.
    juggaloclownz18's Avatar
    juggaloclownz18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    The woods of 315 - NY
    303
    you can test every component of the electrical system before you ever need to do the guess and replace game..... Test your stator, i had the same issue on my big red, and instead of replacing the whole stator, i replaced one of the coils on it (took 2 minutes to solder the new one on) cost me $15 for the coil instead of replacing the whole stator.... Fired right up when i was done, but i knew what my issue was before i spent any money on it..... Just a thought, a multi-meter is your best friend when it comes to bike wiring.... Good luck!
    85 ATC250r (been waiting way too long!!)
    Tusk Hand Guards
    DG full exhaust (want different one)
    TAG handlebars
    +4 LSR axcaliber axle, carrier, hubs
    FMF Carbon Fiber reeds,
    K&N Filter/air box lid removed
    Motion Pro Twist Throttle
    Pro Armor Tether switch
    Seal Savers - long version
    23" Dirt Devil front - 22" holeshots back
    Soon to be ported/polished (got the work setup on trade)
    Saskatchewan
    6
    Thanks for the advice Rug and Jugg. I guess I will start with the proper CDI box and go from there. I do have multi meter. My problem is I need a CDI box as the trike didn't come with one. Also the trike is in pretty rough shape (physically). I want to get it running before I put money into fixing it up (brakes, fenders, tires, etc).
    darrel632 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    alberta
    429
    I'll look and see if I have a CDI for it, no promises though.
    Saskatchewan
    6
    Thanks Darrel. Let me know if you find one.
