I recently broke a black rubber fuel line on my 3 wheeler. I had fuel draining from each end of the broken line plus fuel was draining from the bottom spout of the reserve fuel tank located under and behind the battery compartment. The drain tit has a rubber cover over it but no plug or anything on the spout.
Now, if I swithch the valve selector to " Main" the reserve tank begins leaking fuel from the bottom spout. If I turn the valve back to " Reserve " setting, the fuel stops leaking from the spout..... Now I cannot get the trike to start and run without stalling after a few seconds....
Q. What is with the leaking fuel on the " Main " setting?
Q. Did I hook up something wrong?
