Results 1 to 13 of 13
Thread: 83 200x won't sart
    metairie,Louisiana
    48
    83 200x won't sart
    i need some help i am new to trikes. my wife's grand paw gave me a 83 200x and 2- 82 200 and i got the 200x here and he ran it about 7 years again and ran fine..i change the plug and gap it right and clean the carburetor and i kick it over and it sputtered for about 10 sec and it cut off and i try again this morning and it did that on the second kick.. can yall help me i will be so happy if yall can thanks matt
    squirrel1182 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Derry, Pennsylvania
    253
    When your kicking it over are you giving it a little throttle when your kicking?
    1983 KLT 200 C
    1978? YZ 125
    1978 Panther 5000
    1939 Farmall A, 51st farmall A ever produced.
    1946 International A Industrial
    1973 Ford F100
    metairie,Louisiana
    48
    not today i did not i did that yesterday and i think i flooded it b/c i pulled the plug out and it smelled like gas
    Crest California
    3,014
    When you kick it over, give it gas this time. The idle could be set too low. Don't be surprised if it roars to life like a screaming gorilla
    LED obsessed
    2015 Yamaha FJ-09
    Derry, Pennsylvania
    253
    Quote Originally Posted by Xpress View Post
    Ya beat me to it!
    1983 KLT 200 C
    1978? YZ 125
    1978 Panther 5000
    1973 Ford F100
    metairie,Louisiana
    48
    but it seems that the kick start does not give it enough rotations for the motor..i check for spark and it had a big blue spark so i know that is good..the 82 200 has pull start i need got to them yet that is my next project ..first i want to get this one running and no one around will work on them
    6,819
    Get a new spark plug . Buy an NGK . It probably sat so long that its lacking in compression (sticky or stuck rings) you might need to pull or push start it to get it fired up and once it warms up all might be good .
    metairie,Louisiana
    48
    I put a NGk plug in it brand new I took it out and it had a little black on it
    Crest California
    3,014
    Put it in 2nd gear and try bumping it from about a jogging pace.
    My 200x from a full kick only turns over about 2 times btw.
    LED obsessed
    2015 Yamaha FJ-09
    May 2009
    Minnesota
    457
    Adjust your valve clearance.
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1986 Honda 250sx
    metairie,Louisiana
    48
    I think it is hard to start bc it never been ran in over 6 years it ran great when I was ridding
    it about 7 years ago
    metairie,Louisiana
    48
    well update it started today i put a full tank of gas in it.yesterday i only had a little thought that will get it running but did not so i filled it up today and ran like a champ it is no smoking..ran real good thanks everyone for yall input on it i will post pics of it thank you all
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    ya gas is pretty important ! i had the same problem with my 200X checked everym damn thing except the friggin gas oh well to be old and wise we first must be young and foolish i would clean the carb a couple more times and clean out the petcock too
