Powroll 200x kit
Hi-
I am getting the Powroll 10.5:1 piston kit and "torque" cam installed in my 1985 200x. How is this kit? I did a search and came across a thread saying I need to replace the rocker arms. Is this true?
Second, will the bike run good with the stock 200x carb? Will I need to get a XR200R carb? If so, what year will work?
Any jetting suggestions?
Should I have head work done?
How about heat cycles? I assume the place where I am getting the work done will do this to the motor.
Any other recommendations, tips, or troubles I should look for when getting this installed?
Thanks,
S.
//ArrowChat Integreation Code
