Results 1 to 8 of 8
Thread: restoring a 350x gas tank
    Anaheim
    1,270
    what is that junk you guys are spraying on the inside of these? Krylon? Kremyl? I cant for the life of me remember what you guys are using to re seal these tanks!
    Thanks
    Adam
    86 ATC 500R the duner..
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    Apr 2010
    Jackonville, Fl
    20
    I think what your thinking of is kreme. I hear the por.15 tank sealant is the way to go though.
    Cold Lake, Alberta, Canada
    3,019
    Quote Originally Posted by DeathTrap View Post
    I'm in the process of fixing a tank as we speak with the POR-15 system. I'll let this forum know how it turns out!
    Northern NJ
    706
    I redid a 200x tank that was pretty rusted inside. I used (walmart) distilled vinigar 2 gallons & 2 oz of rock salt. Shook it around for a few hours here and there. Then let it sit for about 12 hours. I hosed it out and it was really clean. Important: when you get most of the water out soak the inside with WD40 or something like that once you have 90% of the water out. If you don't it will rust up lightly within hours.
    It cost like $8 i think. maybe less i bought 4 gallons. & i had rock salt.
    I'm no tree hugger but this was a cool way not have to buy some type of chemical.
    Oct 2007
    Minneapolis mn
    4,067
    Kreme sucks... I removed a Kreme kit from my BR tank, and redid it with a por-15 kit...
    Sep 2007
    100mi west of Chicago
    3,582
    Hey check out this thread: http://www.3wheelerworld.com/showthr...moval&p=854020
    I posted my results with a POR-15 kit
    Rob
    Anaheim
    1,270
    thanks man! so wat do you do to prep the tank or is that all included in the kit?
    Sep 2007
    3,582
    It's all included. You can see in the top pic there is a bottle of cleaner and acid that comes with it.
    Rob
