85 ATC250r (been waiting way too long!!)
Tusk Hand Guards
DG full exhaust (want different one)
TAG handlebars
+4 LSR axcaliber axle, carrier, hubs
FMF Carbon Fiber reeds,
K&N Filter/air box lid removed
Motion Pro Twist Throttle
Pro Armor Tether switch
Seal Savers - long version
23" Dirt Devil front - 22" holeshots back
Soon to be ported/polished (got the work setup on trade)
Thanks bro, i like it! Yeah the blaster and the lt250r i had were rear kick.... Hows she run?
Tusk Hand Guards
TAG handlebars
Thats sweet!
1982 Honda Big Red 200e
1985 Honda 200x- sold
1986 Honda 125m- sold
1986 Honda Big Red 250es
1986 Honda 250sx
Is it fast ? it looks awsome!
Was there any weight savings going to the 2-stroke motor?
85 Big Red 250ES
01 Scrambler 90 (Sons')
Past Machines:
96 Yamaha V-Max 600, 86 200x, 84 200es, 82 70, 82 200, 03 Bombardier DS650, 93 Ski-doo Formula Plus, 87 Ski-doo Stratos, 83 Yamaha XT550, 82 Kawasaki KDX175. 84 Tecate, 86 Tri-Z, 91 CR250.
Two thumbs waayyy up!
Trailpros
there are allways weight savings going to a two stroke haha. but sweet build brotha looks factory!
ATC175R, has a good sound to it.
Looks sweet. I wonder If you could put a CR450R into a 350X? That would be cool and interesting.
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
I wanna see MORE pics!!!!!!
Nice frikkin' job, too.
That ATC175R has a nice twist ,I think I should get some decals made up like the first gen, Ha!.and that CR450R should be a good trans-plant! also the Elsinore MT250 would fit just
like this MR175.Honda~Honda. got to be good....any time you can make a trans-plant without the use of a welder the job will last!!
DO the Best With What you got !
My Feed back :cool
http://s.com/forum/index.php?topic=2528.0 also check this one also http://
s.com/forum/index.php?topic=2995.0
My Feed back :cool
looks good!!
what mods did you have to do for the swap? exhaust, motor mounts ect..
Only the mounts.......The 200x frame was not touched, made the front mount to lift the engine and pull it forward ! the back mount holds the engine up so the center of the drive sprocket is on the same location as the 200x engine..The chassis mounts were just the right width .I put two tabs up and pinched the engine in! the rest was just busy work. The tuner
was from a '79 cr125r, cut to fit and turned it 180! it worked out great.
My Feed back :cool
