The 90 engine only make around 9hp or so. So making sure it's in proper tune and the chains and clutch are properly adjusted and the wheel bearings are nice and free rolling is absolutely critical. But, you can change the tires and change the gearing somewhat and pick up some performance. Then you had cams and carbs and intake and some other bits and all you could do was add power. Some of the hottest 90 engines would run racing gas and alcohol. And believe me, the performance of a stroked and bored and tweaked atc90 is pretty fricking amazing if you have never ridden one. Way to fast for a single drum brake and no suspension.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
