So I got my YT175 a couple weeks ago and its choke cable was rusted and broken. I came up with this fix since I have looked a few times on E-Bay and haven't found anything. Also rather have a new cable than an old one.
This is the repair I came up with that only costs a few bucks and all the parts can be purchased at most bicycle shops.
1. derailleur inner cable, you can get stainless steel. Only a couple bucks more.
2. brake housing, about 6 inches shorter than the cable, they might tell you that you want derailleur housing but it is not as flexible and won't work as well.
3. An Odyessey Knarp, some people won't know what it is but the BMX riders will, or here is a link:
http://www.danscomp.com/512027.php?cat=PARTS
4. A friction thumb shifter, the bike shops that hold onto older parts will have the good metal kind, plastic would work, but metal will last a lot longer. These are also easy to find in junk yards.
5. A housing end and cable end.
Step 1. File the cable end until it fits in the factory choke assembly.
Step 2. Cut housing to length. Fill housing with some oil.
Step 3. Run cable through housing, and the brass piece that screws into the carb. Then install the spring and brass valve.
Step 4. Install on carb and run the cable to the handle bar. Install the thumb shifter on your handle bar. Put the cable housing cap on the bare end of cable housing. Run the cable to the shifter and install the Knarp on the cable. Cut and crimp the cable end on.
This works great. If you have to buy a shifter it still might cost $30, but it works great and it will last longer than the factory set up if you get a metal shifter. Also nothing is modified and the carb end looks and performs just like factory.
I took the picture before I clipped the cable and put the cable end on so it looks unfinished, but you get the idea.
