Results 1 to 7 of 7
Thread: Cant get rear brake drum off please help quick!!!!!
    East Tn,
    39
    Hey i cant get my rear brake drum off.Ive taken both nuts off the axel that hold it in(as looks from the manual)The manual looks like you just pull the drum off but i cant get it out.Ive bent a tire iron trying to get it off.Please help.How does this thing come off?
    Baltimore, MD
    6,088
    You have to take every bit of tension off the brake arm. In fact I would recommend taking the adjustment nut all the way off the rear bar and pulling the lever and that little barrel with the hole in it totally off the rear brake lever if you can. If you have to remove the rear brake pedal to do it, then so be it. What happens is the brakes often wear a lip into the outer edge of the inside of the rear brake drum and then they won't clear the lip until you pull every last little bit of break tension off the brake shoes. Then it should just slide right off. I hope that makes sense?
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    East Tn,
    39
    O great now thats my next problem i cant get the tension off because the brakes sat pulled tight for 2 years and now there stuck with tension ive tried beating the brake lever on the back of the drum cover to releave tension but its not moving.Im afraid im gonna strip the gear.
    East Tn,
    39
    Update got the tention off with some eastman strength lubricant like wd-40 but the drum is still stuck.
    Feb 2009
    Wisconsin
    521
    heat is your friend
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    Walkerallen's Avatar
    Walkerallen is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Wright City,MO
    313
    a may work too. use it like you would to get a car brake drum off. beat it around the lip a little.
    Abrams, Wisconsin
    739
    i had that problem with my sx, had to remove the axle completely and took it to work and pressed it out. YEARS of dirt, rust, and assorted grime can form a bond to rival super glue. FYI be careful whaling on the drum, it's cast and can crack rather easily.
