Results 1 to 8 of 8
Thread: 1985 Yamaha Tri Moto 200 dies when tipped to the right.
    Deweese, Nebraska
    5
    I'm new here guys and need a little help. Have an 85 Tri Moto 200 that dies everytime so go up on 2 wheels on the right side, or even tip it to the right even slightly. It only does it when you tip it to the right or sometimes dies when you go over several dips in a row. I thought it was the carb, but I took the carb off of my other identical trike and it done the same exact thing. I also changed the fuel filter and done it with a full tank of fuel thinking it was starving for fuel since the fuel line is on the left side. It sounds like it is getting to much fuel since it sounds like it is back firing a little through the exaust, it is a 4 stroke and is only pull start, any help would be greatly appreciated.
    N.E. Ohio
    2,005
    Rebuild you carb(I don't mean clean,new floats/springs, needle and jets can be reused if straight and clean)...the fact you have a 2nd 20yr old carb means very little. You could trace the electrical and look for a possible spot that maybe grounding out??
    Deweese, Nebraska
    5
    Quote Originally Posted by Tri-Z 250 View Post
    Thanks for the fast reply. The other carb that I put on is in perfect working order and was rebuilt in the spring and operates my other Tri perfectly, so I just found it hard to believe that it could be a carb problem, if both carbs are doing the same thing and I know that the 2nd carb is just fine.
    Walkerallen's Avatar
    Walkerallen is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Wright City,MO
    313
    check the plug first. but to me it sounds like both of the needle in the carbs aren't seating properly
    1985 Yamaha 225DX-Sold
    1985 Yamaha YTM200n
    1982 Honda ATC110-Sold
    1993 Honda XR100-Sold
    1970 Honda Z50
    "If we didn't do anything we wouldn't be anyone.". Rob Dyrdek
    Quote Originally Posted by x200x View Post
    gee, a 3 wheeler worth 4000... is there something i dont know??? i mean maybe if it is straight out of a warehouse and chuck norris and mr T took part ownership in it... that guy either got RIPPED OFF or is makin 4000 up to make some other tard buy it DUMASS!!!
    Deweese, Nebraska
    5
    The only difference on my trike then my buddies is that his choke cable is all original and much longer then mine, mine barely reaches the front of the gas tank, and on these they run under the tank and into the front of the handlebars. Possibly mine is not the factory one and is not seating properly in the carb, then when it is leaned in that direction it is flooding itself out? The choke cable is the only thing that we didn't swap out today, but like I said, my carb works perfect on his YTM 200 but not on mine when it is leaned to the right side.
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    just only turn left problem solved
    Deweese, Nebraska
    5
    Quote Originally Posted by haggard 2hundie View Post
    A comedian or a genius? Neither.....
    muscatine, iowa
    764
    na just a wisenheimer
