Results 1 to 15 of 16
Thread: Who here mounts their own tires?
    Manitoba
    536
    I get some sort of sick sense of satisfaction out of doing my own tire swaps. I use a boomarang shaped piece of steel I cut that I put on my homemade hydraulic press, for breaking the beads. After that, I use a couple of short, tapered leaf springs as tire irons to work my way around the rim. Lots of liquid dish soap for the seating of the bead.
    Now I wouldn't be crazy enough to say no to the shop if I bought 4 new tires for my truck, but for a single tire or motorcycles and quads, I kinda like doing it myself.
    Anyone else confess that they like doing things the hard way?
    84 200x
    Aug 2007
    Moab, UT
    1,807
    I do all my own tires, but not the hard way. Got a nice tire machine at my job. Though I will say this, 18" Fast Trekkers on 10" wheels can be a struggle.
    3 or die's Avatar
    3 or die is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    southeast
    198
    I do mine too. I slice the tire and break the wire one at a time with whatever is handy. Mounting, I also use soap, pry bars, lots of cuss words, and sweat.
    COLORADO
    685
    I use my Die grinder or sawzall to shop the tire off. i will admit I have ued my Portaband. I use PB blaster or Zep45 to lube the tire, then some 1/4"X2"X16" long irons I made and they all slide on like a fat kid on a cupcake. I Have a Coats 220 machine but the handle is too big for it.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Jul 2008
    MD
    911
    Harbor freight sells a car bead breaker for around $30.. Then 2 tire irons for $7 each.They usualy take about 15 minutes to get them on and off.
    newfane ny
    1,277
    i do my own trike tires , cut the old ones offf the rim slide the new ones on with a little soap , slap a small rachet strap around the tire. let it sit while i do the next one, it seems to give the pressure time to squeeze the tire out, give it a good shot of air and bang its done.
    i do my 9x20 dump truck split rims all myself useing a tire sledge and bars to pop the ring. when i reinstall the new tire i use my tie down chains and wrap the tire and split rim so if the rim pops it wont kill me, its allso chained to two giant chains mounted in our 12in thick concrete floor, i have had the ring pop but the big chains keep it in place.
    Beaver Falls, PA
    2,666
    Quote Originally Posted by 86trizinger View Post
    I've been wondering about this bead breaker... it works well, then?
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    I do my own with a homemade beadbreaker. The only ones I haven't been able to get with it was a pair of stock Blaster rears. Even the 20 ton press wouldn't get 'em. I took them to a motorcycle/ATV shop and it took them a half hour with their power breaker. I bought a pair of beadlocks for my R. That makes tire changes MUCH easier! I have done a car tire by hand and it was actually easier than an ATV tire.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    N.E. Ohio
    2,005
    As a HINT to the do it yourselfer....when setting the bead use a tie-down strap to miniumize the expantion of the tire. BE CAREFUL!!! You can snap a tie strap quickly so take note. The strap wraps around the tire along the centerline of the tread(causes tire to expand width wise and not tall). Use only 50psi to set the bead, with the valve stem pulled with LOTS of liquid soap...NOT WD40! Once she pops replace stem to correct psi.
    Jul 2008
    MD
    911
    The harbor freight bead breaker works great so far as long as you get the one for the car.. the motorcycle on is too small. I'm not gonna say it will work on all tires.. but so far I have changed 8 tires with ease.
    84atc200's Avatar
    84atc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    new cumberland
    216
    Quote Originally Posted by 3 or die View Post
    Thats my method
    Oct 2007
    Minneapolis mn
    4,067
    I usually do most things the hard way, but for 8 bucks a tire, I dont screw with it....
    Sep 2007
    100mi west of Chicago
    3,582
    Quote Originally Posted by Thorpe View Post
    same here
    I have the Harbor Frieght atv set but I bent the crap out of it the first time using it lol. I got the 2 tires changed but the tool is pretty much junk now.
    Rob
    Walkerallen's Avatar
    Walkerallen is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Wright City,MO
    313
    i do my own too.
    1985 Yamaha 225DX-Sold
    1985 Yamaha YTM200n
    1982 Honda ATC110-Sold
    1993 Honda XR100-Sold
    1970 Honda Z50
    "If we didn't do anything we wouldn't be anyone.". Rob Dyrdek
    Quote Originally Posted by x200x View Post
    gee, a 3 wheeler worth 4000... is there something i dont know??? i mean maybe if it is straight out of a warehouse and chuck norris and mr T took part ownership in it... that guy either got RIPPED OFF or is makin 4000 up to make some other tard buy it DUMASS!!!
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    I cut out a plate that fits halfway around the tire, just bigger than the rim and welded it to a 4' piece of pipe. Drive the Z-71 up on the pipe and the tire breaks right off. It has never failed. I also have found that the bigger the tire, the easier it is to mount and dismount. Tractor tires are easier that ATVs.
