Results 1 to 7 of 7
Thread: hondaline 300 bigbore cylinder and head ?
    tri-shee is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2002
    Texas
    333
    I have a 300 bigbore cylinder and head for a air cooled 250r and i was wondering what do you guys think it is worth ?
    Southern MN
    1,875
    Its hard to tell. Is the head in good condition? Any broken fins? What size is the bore on the jug? Does it need to be bored or sleeved? Is there a piston included, and was there any port work done? All these will effect how much it is worth to the right buyer. If it is on the stock 300 bore and port specs and no scores, and no broken fins, and nice paint with a piston, it could be worth upwards of $300 minimum. If it is beaten and not usable, it would be worth aluminum scrap at the scrap yard. It all depends...
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Nov 2002
    Texas
    333
    The head has two broken fins on the gear shift side of the motor . It looks like they trimed the two fins to maybe clear the exhaust pipe . Do you know what the stock bore is mm ? I do have a piston and maybe the rings .
    Jul 2006
    the sleeves will also crack and thats VERY common.. at first inspection they will look fine and after closer inspection they have hairline cracks forming... the sleeve is toast, also hard to get pistons unless you get a resleave and modded piston from somewhere, so unless it came off a perfect running machine I wouldnt say much, its just another 300 kit.
    Jan 2004
    Palmetto,Florida
    2,300
    SYKO !!!!!!!!!!!!!!!!!!!!! i was gonna call you when goen thru Ga.on the way to TF2010 but...................... IT WAS 3 AM !!!!
    "07" DR650 Suzuki Dual Sport
    Nov 2002
    Texas
    333
    Quote Originally Posted by Yamaha_Rules69 View Post
    The bore is 3.003" , the head chamber is good with no pitting . It has 25 on top of the piston . I believe the cylinder has been bored .010" . No port work has been done , all stock .
    rayatc84's Avatar
    rayatc84 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2010
    France
    194
    I'm searching for a hondaline 300 head for my '84 250R, or eventually a complete hondaline 300 kit (cylinder + head + complete piston kit + gaskets).
    If someone have it, please let me know.
    Outside of engines with holes that stink, there is no salvation...
    My feedback thread: here!
    Want to see overseas 3wheelers? http://www.passion-atc.com of course!
    YT60 Tri-Zinger, YT70 Tri-Zinger modified, '84 ATC 70, '82 ATC 110, '82 250R, '82 250R modified, '84 250R, '84 480R in build, '85 310R, '86 250R, '87 250ES BigRed, '84 FL250 Odyssey, '85 FL350 Odyssey
