I just bought my first trike two weeks ago and am now faced with an electric start issue. The battery was weak when first purchased as indicated by a clicking noise in the starter motor. After charging the battery, the electric start worked great. Now I get nothing when I depress the starter button. Both fuses are good. Does this sound like a common problem? The lights all work; headlight, tailight, neutral/reverse indicator. The lights do not dim when the button is depressed. The lights come on and are very bright when the key is turned on. Also the trike starts fine with the pull start. Any help any one could give would be great.
