200es big red can't get to full throttle just bogs out help
Remove carb - remove jets - clean jets, re install jets, reinstall carb, give her a go - sounds like a dirty carb problem to me!
Plugged fuel filter limiting flow? or collapsed fuel line?
Trikes
1970/71 US 90 (Aquarius Blue)
1972/73 US 90 Green
1982 ATC 70
1983 ATC 70 (Ladybug)
1973 ATC 70
TF 2015
Other
1983 Honda Z50
had carb of no dirt in at all and fress fuel in tank
it has new fuel line al clean filter in tank and try again
The ES carbs are finicky with the smallest bit of crud in them... I had to take mine apart twice and rebuild it to get it running correctly. Also, double check and make certain the jets are correct size. I got a rebuild kit once with the wrong main jet (way too big)
Are you sure what machine you have? There wasnt a 200ES in 1985... 1985 was the first year of the 250ES
put new jets in carb still the same tryed mates carb still no joy .it is a 1985 200es
I would start looking at timing, and also making sure the exhaust isnt plugged... Mice have created plenty of problems in exhaust systems....
ive moved the timing pulse rotor still runs the same. it runs good on half choke
How is the exhaust? If it runs decent on half choke, it leads me to believe you need to fatten up your jets.... (it isnt a former "high altitude" machine is it?)
If it is a 85 200es it is the first one I heard of.
85 Big Red
83 Big Red
84 125m
85 TRX 125
73 ATC 70
not had exhaust of yet waiting on new cobar exhaust on way. it has a 95 main jet ,just notice inhibiter realey missing
He is wrong on either the year or the model. Need correct info before you start asking for advice. >< As stated before 84 is a 200es 85 is a 250es COMPLETELY different bikes .Otherwise post pics of the VIN tag
Bikes I currently own.
1985 250sx with Hondaline Tank Cover
1986 Tecate with 1998 KX250 motor Eric Gorr 285 big bore kit.
1985 200x sold
1986 200X in restoration
1981 110 stock
1987 Big Red
1985 250r doing total frame off rebuild.
1985 350x with 86 fenders
1985 350x in excellent original shape.
1987 atc125 Near perfect.
In Soda's defense, I do believe that in other parts of the world, Honda did infact make a 85 200es... (not positive, but thought I read into that here on the forum somewhere...) Sure would like to see a picture or two!
the bike is a 1985 200es the only differance is the stickers on the tank and back mud gards
