Thread: need motor swap help!!!
    Minnesota
    hey im new to this, i just got and early 80's atc 110, i was wondering if there were and motors that are bigger that swap in easly?? please help?!?!?!
    Beaver Falls, PA
    2,666
    almost any lay down (horizontal) pit bike motor up to 140cc's or so should bolt right in, but you'd need the wiring harness, etc. from the new engine
    Ripley Tn
    1,363
    the pit bike motors you will have to shim they are 50 and 70 size case's not the size of the 110 case's
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    north east
    3
    i am not positive but i think you can put a 200 on that trike there are lots of them out there
    Jul 2008
    MD
    911
    200's are not gonna fit easily. DR ATV sells the brackets you need for $15 to put a pit bike engine in.
    bobotech is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    spokane, wa
    363
    Tell me about these pit bike engines. What kind of power and strength do they have? My 110 is somewhat lacking in power due to me being a big guy.
    Jul 2008
    MD
    911
    I have a 140cc Piranha engine in mine. Rated at 11hp.. Makes alot of power on the top end but has decent bottom end as well. I weight around 200lbs and it will pull the front wheel off of the ground with ease. I am not sure how much you weight though. I paid around 350 for the complete engine with all electronics and carb.
    Dr atv sells the adapter for $14 and if you want to use stock 110 pegs they also sell the foot peg adapter. Then you can just run a pit bike exhaust and bend it slightly to fit. I paid $60 for my exhaust
