I found a honda TRX 125 in a junk jard, with the horizontal engine all there.
Will it mount in a ATC\US 90 fame? with modifications?
you'll have to make a battery box the rear of the motor by the high and low gear box i think is a little wider too
85 Atc 70
86 Atc 125m
85 atc 350x
86 atc 250r
86 Atc 250r TT build
85 Big Red bought brand NEW
2012 Honda Goldwing Gl1800
I'll probably only use the hand pull to start, as I do on my 2 others now
I don't want to modify a frame if I go vintage route, if I can find a Nicholson or similar may do that path. Anyone do this before?
