Thread: 85 Big Red Shock Leak
    Cold Lake, Alberta, Canada
    3,013
    Question 85 Big Red Shock Leak
    Seems like a silly question but I have developed an oil leak from the allen head bolt on the underside of the shock tube. My questions are; Is this oil under pressure? And, is it as simple as taking out the screw, putting thread sealer on it and re-installing? What type of oil is used, it appears to be clear. Any tips would be great.
    I mean "Fork" leak
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    I did not think the SX or Big Red shock could be serviced.......
    Tionesta, PA
    5,743
    I think he is talking about the front fork........I think
    If he is - there is a copper washer under there to seal it - you'll want to replace that. they are not under pressure - and they use standard motorcycle fork oil.
    3,013
    My mistake. Yes it is the fork that leaks. Thanks for the ideas!
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Oct 2007
    Minneapolis mn
    4,067
    Honda used ATF in the forks from the factory, not fork oil... (either one would be just fine... Fork oil is more tune-able though)
