Thread: 82" atc250r kick too easy
    springfield
    9
    i have a question for somebody, i have an 82' atc250r and it seams to kick really easy to start. it starts every kick but sometimes the kicker will go almost down and the last little bite will start the bike. would that be lack of compression. idk but it always starts even dead cold
    Feb 2009
    michigan
    2,387
    do a compression check to find out
    1985 ATC 250R
    . Team Red Trike
    Mr.Atc's Avatar
    Mr.Atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    gulliver,mi
    248
    if it starts when its cold try starting it and taking it for a nice 10 or 15 minute ride get it nice and warm then shut it off and try and start it again if it is lack of compression then it probably wont start when its warm if it is it will need atleast a set of rings but if your going to rebuild it go all the way and put a piston in its not that expensive also if you check the compression if its below 80 pounds then id probably rebuild it but yea that sounds like a compression problem
    springfield
    9
    i appreciate the info i will try it right now
    Southern MN
    1,875
    If it aint broke, dont fix it! Ride it till she blows, then rebuild it.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Mr.Atc's Avatar
    Mar 2009
    gulliver,mi
    248
    no problem
