quick question i got a bit of oil leaking out of my kick starter, what is the problem?
p.s i checked the oil every time and it doesn't seem to be going down.
i'd like to learn about this problem too
there was a bike that i was looking and it was super cheap. the only thing wrong was a leak at the shifter.
sounds like the seal (shifter seal) that goes around the shaft and slides into the case is bad . you can get it at practically any motorsport dealer for about 5.00 or so.
down to parts because i no longer have a place to ride trikes.![]()
GIT IT RAAAGGGGG !!!!
but its at the kick starter though** not the shifter
oh sorry bout that yamaha guy
not trying to hijack your thread
there should be a seal for the kick starter as well
ohh, noo worrys dont worry about it, but it could be the same thing, it could be the matter of the seal around the kick starter
i kinda figured it would be a seal of some kind on both
what im tryin to figure out is whats involved in fixing the seal
that i cant say for sure . but i imagine it shouldnt be too bad or too long of a job .
yeah i agree
seal can be chaned by jsut removing the kicker off the shaft, then using something to gently pry the seal out.. onc eout, clean erally well, I liek to use a tony dab of black hi-temp silicone around the outer edge of the seal and then install it. this helps ensure a good seal to the case and helps with install. should take about 15 min to do.
________________
https://www.mikesatvfix.com
yeah there should be a o ring between the kicker and the shaft i the case good luck
no more toysmaybe buy a 250r?
past:
86 250r
88 quadracer
83 200x
what should i use to pry it out without damaging it?
use a very fine regular screwdriver and ato try to tap the seal out with or something with a sharp point to pry it out . ive used both methods and they both work good but sometimes there is no saving the seals .
where could i get a seal if i damage it?
