Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: 86 250r subframe...
    O.C., Oregon
    921
    Question 86 250r subframe...
    Hey i just got an 86 250r and noticed it have a sub frame that can pivot under the seat section.. Just wondering if all the r frames are like this or if it's somebody modified it before i got this bike??
    Ontario, CANADA
    4,538
    Like flip up??? pics please!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    O.C., Oregon
    921
    Yeah it flips up, it has hinges at the top and they slide over the posts at the bottom,. i'll post pics when i get home later...
    O.C., Oregon
    921
    I've looked at alot of R frames and didn't see any that had this so that's really why i'm asking
    Dec 2007
    521
    pot pics sounds cool
    A Rental Car is the only true all-terrain vehicle.
    " I actually think it is good that you have clubs where people can go and enjoy riding these things together. It reminds me of how the prisoners on death row have fun waiting for their turn on the electric chair. Fair enough, the trike isn't an electric chair, but it is about as safe and comfortable as one."
    http://www.nps.gov/bicy/
    Oct 2009
    FF, Man.
    774
    maybe its an ultra rare aftermarket frame from the 80s
    Las Vegas, NV.
    2,516
    Somebody has modified that frame. None of the stock R frames ever had a detachable subframe from the factory.
    OK
    5,450
    Was it Laeger that sold an atc 500 frame with the flip up subframe so you can kick it rearward?
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Aug 2007
    Moab, UT
    1,807
    Yes it was. It was a kit to transform a CR 500 into a trike. On another note, CT used to sell an aftermarket aluminum subframe that would attach to the stock R frame after some modifications.
    O.C., Oregon
    921
    So here are a few pics i snapped this morning, you can see the hinges at the top of the frame and the posts at the bottom, the guy i bought it from tack welded the posts so it wouldn't slip off and the gas resivour for the shock is also welded to the frame and the subframe so it doesn't pivot at the moment But with some cleanin up it should go back to the way it was but my only question now is where to relocate the gas resivour and the how to get the air filter to work cause the stock one obviously won't work with a pivoting subframe, it's got a K&N filter so should i just take off the stock airbox and run it without it or just weld the damn thing together and forget about it?? If its a rare thing to have this frame then i would like to keep it since it sounds like it's pretty rare...
    Attached Thumbnails Attached Thumbnails subframe1.jpg   subframe2.jpg   subframe3.jpg
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    Jun 2009
    Tunkhannock,Pa
    904
    I looks to me like the sub frame broke at one time and who ever had it just cobbled it together i would find a frame and go from there
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    O.C., Oregon
    921
    the frames in pretty good condition and there are posts that the subframe slips over so i don't think it was ever broken
    2017 YZ 250x- Braap
    Baltimore, MD
    6,088
    I really don't see a practical use for a subframe that pivots forward. And it doesn't look like there was any way to latch the subframe down. It probably bounced alot in rough terrain. If it was on another trike where a rear kicking engine was custom mounted, it may have been a help but I don't see where it would make much of a difference on a relatively stock R. And it doesn't seem to have been very well thought out at all. I would be cool sitting around the campfire to show off the back end of your trike, but that's about it as far as I can tell.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    O.C., Oregon
    921
    Thats kinda what i was thinkin so i'm probably just gonna weld up the subframe to the posts and leave the hinges on top and get the whole thing powder coated black and go from there...
    2017 YZ 250x- Braap
    Baltimore, MD
    6,088
    Just be careful. These honda frames aren't the heaviest duty frames I've ever seen. And since your frame has already been welded on several times, it may have actually weakened your frame. It's your trike and your call, just be aware all those previously welded spots could be possible problem areas. If you do alot of jumping or really hard riding. Make sure to check those spots for cracks. It's better to be safe.
    Nicholson 185s
