Results 1 to 8 of 8
Thread: compression test on atc 350x
    ustin666 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2009
    moncton
    237
    i did a compression test on my 86 atc 350x and it was 100psi is that to low???
    Jun 2009
    Tunkhannock,Pa
    904
    yes it should be about 175 psi
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    Was that done motor cold or hot? Did you have the throttle wide open?
    When the motor's warm and you have checked the compression, squirt a little oil into the plug hole and test again. If the pressure jumps up it points to the rings / bore being worn. If not it's more likely the valves. (Could also be the head gasket).
    Plattsburgh, NY
    2,311
    Also make sure u unhook the decompressor. Seems like u didn't do that. I just did mine and it tested at 174. Let it idle for awhile or drive it around a bit to warm it up.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Dec 2009
    moncton
    237
    i had my throttle wide open and my engine was cold.
    WilliamJ's Avatar
    Apr 2010
    Poole, England
    157
    Okay, you should really test the compression with a warm engine as Tattool's post. That said, you don't get an increase from 100 to 175 psi - cold to warm. Check that you have got some clearance at the valves as well.
    If with a warm engine, correct valve clearances, you can't get the compression over 150 then you'll need to strip it. If the squirt of oil puts the pressure right up it usually needs rings and a bore hone as a minimum.
    Dec 2009
    moncton
    237
    i was looking at the 452 sleeve. http://kustom-kraft.com/hondakits.html
    Dec 2009
    moncton
    237
    i did a new compression test and it was 120psi dis time. i disconnected the decompress er and wormed up my engine.I am going to adjust my timing because I know it is of a Little bit off.
