Results 16 to 30 of 33
Thread: Any other shocks for the rear of a 250sx?
    ct
    1,396
    keep us posted please !
    Jul 2008
    MD
    911
    Got the engine back in this morning.. Been short on time. Airbox is tight fitting with the fitting on the shock. I think I can squeeze it in without cutting it though. Still have to wire up the engine so I will have an update by the end of the week.
    Oct 2007
    Minneapolis mn
    4,067
    Ooh ooh.... I am getting excited!
    Worcester, MA
    1,117
    I'm also interested.
    If the airbox is in the way, snorkel it! Or just cut the needed length removed off the airbox, then solder/plastic weld it together once it's smaller and out of the way. Unless it's a different issue with the airbox getting in the way.
    Jul 2008
    MD
    911
    Shock is all bolted up. Air box flexed about a 1/4 of an inch around the shock with no problem.
    There were only 2 issues with bolting up the shock. One is the bolt size being about 2mm larger. I made a bushing out of a piece of tubing to get this to work. The other issue is where the top shock mount is I had to grind some metal off of the bottom so the shock could clear fully compressed. Other then that the shock is the exact same length as stock.
    I test fired the engine just now and it seems to be idling great. Now I have to do is mount the shock reservoir, battery box back and foot pegs back on for a test ride.
    Oct 2007
    Minneapolis mn
    4,067
    Oh man... We need some ! Liking this thread! Be needing to get a new shock for my BR now!
    Worcester, MA
    1,117
    Did you use the wishbone/linkage on it? Or just the shock itself?
    Oct 2007
    Minneapolis mn
    4,067
    Alright Zinger... We need an update!
    Quote Originally Posted by TheRealFatShady View Post
    Probably not which made the spring so tough to compress.
    Lets hope it works well and clears the battery box.
    Years ago I mounted a different shock on my SX and ground that top mount a bit, it cracked the frame in time.......
    Better shock means bigger jumps and bigger jumps mean bent rear swinger/axle.
    I hope it works out for the less aggressive riders though.....
    Worcester, MA
    1,117
    I think I actually saw those pictures
    http://cgi.ebay.com/ebaymotors/Rear-...Q5fAccessories
    Kind of dirty, but shows they can be had cheap. Maybe if I ever get around to extending and/or lifting the big red, I can use the full setup. A lift means more shock options as far as length, meaning no lift + longer/taller shock for the height I want, or more lift for a shorter shock.
    By the way, I snagged another X frame that's decent, and my heel guards came in. Interested?
    Jul 2008
    MD
    911
    Sorry for no response yet. I am loosing spark for some reason and I have to narrow that down.
    So far I have put about 15 minutes on the shock is all. Jumped it a 2 or 3 times. As of right now it's a little stiff on flat ground but jumping about 2ft - 3 ft it felt great. I have another softer spring coming in 2 weeks once I verify the spring dimensions.
    That eBay link shows the shock with the reservoir attached.. You actually want a 2001 model where the reservoir is remote mounted. I will pull it out of the shed this weekend to take a few pics of it. It fit with both the air box and battery with no problem. The only thing is had to do was make spacers for the bolts.
    I don't do jumps that are big but I can already tell a difference.
    Oct 2007
    Minneapolis mn
    4,067
    Thats awesome Zinger!... Where are you buying the softer springs from?
    Jul 2008
    MD
    911
    I am looking into some other atv's that have a same spring size but a softer rate so I can keep the cost down.. If not Eibach said I can get one for $100..
    I am in the middle of two 4 page pagers due Monday plus a few other projects due on Tuesday. May be until next weekend before I can update anything
    Oct 2007
    Minneapolis mn
    4,067
    Hows progress?
  15. #30
    Jul 2008
    MD
    911
    I was waiting for my clutch parts to come so I could get it done. It's definitely gonna need a softer spring but someone tried to break into my garage last night and this morning so I have to figure out how to make it safer.
