Results 1 to 12 of 12
Thread: 28mm FCR for my 86 200x?
    Gods Country, MS
    209
    Cool 28mm FCR for my 86 200x?
    Whats up guys. Im new on here but have loved the good ole bikes since i was a kid and have had several since. Now im into 300ft drags and build big bore stroker raptors pushing around 100hp. Well I run across a real clean 86 200x the other day so i picked it up. Im looking into a big piston, port job, big cam and bigger carb. Im a big fan of the FCR carbs, thats all we run on our big motors. Im thinking of running a 28mm or 29mm FCR on my 200x. What do you guys think?
    Coal Shed Racing
    Beasley's ATV Services
    DEAF MAN CHASSIS
    EKO Engineering
    2 of the fastest 300ft raptors in the country..
    847cc 100hp+
    720cc 75hp+ (play bike)
    1986 200x, 1986 350x, 1984 110
    Feb 2003
    Australia
    927
    I used to run a 29 FCR on my old 84 racing 200X. I had to fit a boltable flange and make a small "v" on the slide to make it idle but apart from that it was all good.
    Gods Country, MS
    209
    Yeah i've also looked at that. It shouldnt be a big deal to make it work. What size is a stock 200x carb? 27mm?? Im thinking I could probably easily go to a 30mm FCR without problems.
    Coal Shed Racing
    DEAF MAN CHASSIS
    EKO Engineering
    847cc 100hp+
    6,810
    Quote Originally Posted by Cuztom Racing View Post
    Stock is a 24mm
    Jun 2003
    englishtown NJ
    2,676
    I put a 27mm PD carb on mine. I don't think that fcr carbs go below 39mm. Mikuni pumpers do, w/ a big carb, I'd be concerned over clearance between carb and gas tank.
    Sep 2003
    Elizabethtown PA
    1,581
    The 200x i used have that was in a trx250r chassis used a 32mm electron carb. It was a Tc dual plug motor.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Gods Country, MS
    209
    Quote Originally Posted by deathman53 View Post
    I know they make 35s, we also run them on our raptors. They actually make more torque but less hp than the 39s. But i have googled images of 29mm and 30mm FCRs and seen several pictures of em so im assuming they make them. The guy that does my head porting is a sudco dealer and im having him call tomorrow to see if he can get one..
    So 24mm is stock?? Wow thats under sized for a 200cc motor i would think. Im going to try a 28 or 29mm if i can get my hands on one.
    Coal Shed Racing
    DEAF MAN CHASSIS
    EKO Engineering
    847cc 100hp+
    Mar 2005
    overton, PA
    5,257
    keep me posted also i wanan make the 86 i have brethe a bit better and run a lil stronger.
    Gods Country, MS
    209
    Well do man, i hope to get started on it in a few days. I think the little motors have alot of potenial. Im interested to see what it will do with some quaility portwork and good carb. This is what im thinking. Wiseco 10.25:1 66mm piston, full race web cam, full race port, ported intake with 30mm FCR carb.
    Coal Shed Racing
    DEAF MAN CHASSIS
    EKO Engineering
    847cc 100hp+
    Feb 2003
    Australia
    927
    They do make them in 29. They came as a bank of four carbs off some motorbike. I now remember I had to tap in a fuel inlet connector as well as making a top plate to hold a cable adjuster. They come standard with some lump of a thing on top to hold the bike cable setup.
    Gods Country, MS
    209
    Check these FCR's out i found! Im think im going to get the 30mm, but hey also offer a 33mm! Should be a beast when i get her all together!
    http://www.ctracing.com/raptor_250.htm
    About 3/4 down the page.
    Coal Shed Racing
    DEAF MAN CHASSIS
    EKO Engineering
    847cc 100hp+
    Fresno Ca
    2,695
    Pick up one of the FCR's from the honda CRF150r That has a small FCR on it. It would work perfect.
