I searched and couldn't find any specific info on this transmission. I'm interested in this unit for a project I'm doing, but the info i can find is scarce. I need to know if it's a seperate lo-range, or if it's just a low first gear, I've heard both, so I am not sure. What are the gear ratios, first through 5th, and reverse. Apporox weight? Is this tranmission offered in any other atc's? From the info I'm asking, can you recommend any other type of tranmission that would suite my needs(5spd, reverse, low range) Any other cool info? Thanks a lot for the help. _nicko_
