Results 1 to 9 of 9
Thread: excessive carbon
    84atc200's Avatar
    84atc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    new cumberland
    216
    excessive carbon
    What causes excess carbon? On my 185s there is a small leak where the head pipe joins the muffler, there is black on the fender and on the grab bar.When i take the plug out it is heavily carboned up.
    1,736
    either its running very rich or its burning oil
    Feb 2009
    michigan
    2,387
    bingo^^^^^^
    1985 ATC 250R
    . Team Red Trike
    goump1995's Avatar
    goump1995 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Louisiana
    167
    Running rich or oil ring is seized.
    84atc200's Avatar
    new cumberland
    216
    I think its probably running rich, i took the carb off and the fuel screw looks like its turned out too far.
    1,736
    does the exhaust smoke? Like a white blueish smoke? if so its burning oil. if not then your probably rich. if its super rich you might find it blowing black smoke when at very High rpm/rev limiter.
    but hopefully your just running rich because thats easier and cheaper to fix =)
    good luck
    84atc200's Avatar
    new cumberland
    216
    its smoking a little, i have some oil leaking into where the flywheel is i just found
    1,736
    well if its smoking that means oil is getting in the combustion chamber and burning. its very common on our old trikes. it may just be a worn valve guide seal, or it could be worn piston rings.
    either way you might as well replace both while you have the engine apart if you decide to take it apart. its something all our 24+ year old trikes come across. hopefully its not an immediate thing but sooner or later it will be time to rebuild it.
    84atc200's Avatar
    new cumberland
    216
    By the looks of the motor its never been torn into,I'll be the first i guess.I have a good piston and new rings from my 200s i might put in, the 200s cylinder is in really good shape too.Thanks for the help Mr_RPM.
