Results 1 to 15 of 18
Thread: Gasoline Problems
    Dec 2002
    Kansas
    2,387
    Gasoline Problems
    I have a 92 Lexus sc400 that I drive as a work car. It requires 91 octane, runs great all winter then in the heat of the summer it starts acting up, spitting, sputtering, cutting out, dying at stoplights. When it does that I have to put heat in and octane booster for a couple tanks and it will clear up and run good again.
    I suspect where I fill up might be putting 87 octane in the 91 tanks. Because it runs the same as when I fill it with 87. Seems like anytime my car even gets a whiff of ethenal and it starts running like crap. Car never had any problems until the government invested in ethenal plants and required everyone to run at least 10%.
    Anyone else having this trouble?
    I had the RIGHT to remain silent, I didn't have the ability!
    N/A
    5,818
    i have not heard of this in cars but in streetbikes yes its been a royal pain with carbed motorcyles.
    i would try and put 91 in from a dif station, if it cleans up some maybe you can have that gas station investigated. it wouldnt suprize me for somthing to sell somthing its really not these days.
    COLORADO
    685
    Every Shovelhead I built got 91 or higher, and it would have similar problems. I ended up running Sinclair stuff. They had a hot fuel tank
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    1,736
    http://www.sunocoinc.com/site/Consum...T100Locations/
    street legal high octane gas, that shouldn't have ethanol either.
    i have it right in my area, look into it. maybe running 50/50 with 91 would work good for you
    Dec 2002
    Kansas
    2,387
    I have filled from a few different stations, always about the same result this mornings fill up was horrible, it will take a couple bottles of heat to get this mess cleaned up. We don't have sunoco around here. Just blows my mind that the government can subsidize (sp?) the entire ethenal industry then force everyone to run at least 10% of the crap. What a business plan invest in it then force everyone to buy it, wish I could do that.
    Mar 2005
    overton, PA
    5,257
    what do you think heat is iyts methanol iceline antifreaze????????? prolly just moisture in the gas and the heat/ methanol absorbes a percentage of it to make it burnable/.
    Dec 2002
    Kansas
    2,387
    Yes and this new gas has to much water in it with all the ethenal crap.
    Mar 2005
    overton, PA
    5,257
    i think its allowed up to 16% water in pa
    Mar 2005
    overton, PA
    5,257
    go figure they used water to control detonation from the teens all the way up until the 50's
    OK
    5,450
    My 1992 Acura Integra GSR was specified to run 91 octane, you could run 87 0r 89 octane. But the ecu would retard the timing via the knock sensor.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Dec 2002
    Kansas
    2,387
    Mine ran good on 87 until last year until all gas started getting 10% ethenal mix, ever since then I have fought this problem off and on, thought it was fixed for good by running 91 until a few weeks ago when it started missing again. I drive 92 miles per day to and from work so I hate to spend $10 per week in heat and octane booster. This Lexus is a great car to drive and I would like to run it up to 3-4 hundred thousand miles but if this keeps up I will be buying some crap box new cheap car and never be able to pass again.
    N/A
    5,818
    have you tried higher like 93...just to for shitz and giggles at all? also do you know how the plugs are? maybe you could just take it to a lexis dealer and ask them if they have seen anything like it. maybe there is somthing they could recoment and or do to help you out. im sure you cant be theonly one experiancing this.
    Northern NJ
    706
    Change your fuel filter in the car. If it's never been changed I'd start there.
    WNY
    517
    Do they have any kwik fills around you? They dont have any Ethanol in their gas and it's American oil/gas. If the gas station has Ethanol in the fuel it has to be marked on the pumps, look for a place that doesnt use Ethanol. When was the last time the car had a tune-up? Oxygen sensors ever been replaced? If this car has a Mass Airflow Sensor when was the last time it was cleaned? Also sounds like crappy gas, I'd start filling up somewhere different.
    85 Big Red 250ES
    01 Scrambler 90 (Sons')
    Past Machines:
    96 Yamaha V-Max 600, 86 200x, 84 200es, 82 70, 82 200, 03 Bombardier DS650, 93 Ski-doo Formula Plus, 87 Ski-doo Stratos, 83 Yamaha XT550, 82 Kawasaki KDX175. 84 Tecate, 86 Tri-Z, 91 CR250.
    topless is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    Kansas
    160
    I live in Kansas too. I love boosted cars and have for many years and about 5 years ago we lost all of our 93 octane pump gas. At the time I had an Eclipse GSX that was not stock. I spent a while with my data logger trying 91 octane from different stations to see if there was a difference. Since then I know other guys have done the same thing to confirm my findings. I now have a OBD2 scan tool that will do live readings on any '96 or newer car (they must have knock sensors to get this reading) and recently checked 91 again in my turbo wagon. I found the 91 at Quik Shops and Dillons stores caused the least amount of detonation. Quick Trip gas is the worst, it has a lot of detergents, but detergents are solvents and not gasoline and don't help with detonation.
    However, it sounds to me that your car may have a problem with vapor lock. I had a VW that would just die on hot days and after getting stranded a few times I traded it off, then found out later they had a recall on the fuel injection for vapor locking.
