Can you swap a spring off of a 1985 350 and make it fix on a 1985 250sx?
Um... Clutch spring, valve spring, fork spring, shock spring, kicker spring....? You can do anything with the right tools and enough money....
shock spring sorry i wasnt thinking
Do you mean the whole shock, or just the spring? The SX spring isnt intended to be removed... (no simple way to disassemble with cutting the shock up)
just go buy a works shock to redo the rear end or do a 200x front end if you want better suspension.
