So after a week of owning this '84 125M I decide to clean the carb to see if I can get it to idle. Needless to say the carb was filthy and the slow (pilot) whatever you want to call it was totally plugged. So I get it spotless with all passages and jets clean and blown out with compressed air and now it still won't idle. When I turn the idle screw in it will increase until it gets to a point that it idles too high and takes a while for the RPMs to come down after hitting the gas. If I turn it out where it won't idle it runs fine.
Current settings
Needle clip one down from the top groove. (Stock position I believe)
92 Main jet (stock)
Stock slow jet
Fuel Screw 1 1/2 turns out (tried it all over, in and out with no help)
Clean (new) air filter
Float level at .400"
I also just adjusted the valves 0.003" I even checked the timing marks and the cdi pickup gap. Everything looks good. 150 PSI compression.
Help!
