Thread: Early 250R Triples in 200X Neck
    Apr 2006
    SE CA Dez in the sandbox
    892
    I've got a new project. I want to go "old school" 250R front end on a frame with a 200X neck.
    What would you think the cleanest way to accomplish this would be?
    Have '85 350X-XR500 Hybrid,
    Had Nicholson framed: 90/110, 185s, Gen I 500, Gen II 500
    Had Bandito Framed 90
    Have Vey's Framed 90
    Have too many parts
    6,798
    Quote Originally Posted by RapidRick View Post
    The 83-84 250r front end goes right in a 200x if you use the 250r bearings . Gives you 9" front suspension . If you look threw your old mags and look at Curtis Sparks set up on his 200x that was the old school way to go . If your talking a 85-86 250r front end its to big IMO and looks out of proportion . Both my 200x's have 250r front ends on them .
    Oct 2009
    FF, Man.
    774
    I know 81-82 R and 83-85 200x have the same steering stem with loose balls
    Southern MN
    1,875
    The 85 200x had the caged roller bearrings in the neck, like the 83-84 250R, and the 83-84 200x used loose bearrings. Doing the swap on the 83-84 200x with the loose balls would be tough, because they dont use the same tapered races for the bearrings to sit in. I tried to put 84 R forks on my 85 200x, and couldnt get it to "bolt right on" if I remember correctly, the steering stem in the neck was a little too long, and the bearrings on the R neck were slightly smaller and didnt fit right in the races of the X neck, and there was a LOT of play. I tried shiming the bearrings with various thickness washers to compensate for the slightly longer stem, but could not make up for the excessive play of the bearrings. It had over a 1/4 inch play, if not more.
    Im not saying it cant be done, but I had a hard time, and said screw it. Im not sure if you have to swap the races inside the neck to 250R, or if they will fit right in. I didnt have the races on hand. I wish I knew what had to be done to get it to work. Maybe the 83 R used the exact same bearrings, stem and races as the 200x?
    I know the 81-82 250R can swap with a 83-85 200x all day long. People do it all the time the the R, because they didnt have very good suspension, and the skinnier tire and better disc brake was a plus for most. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Apr 2006
    892
    Quote Originally Posted by Yamaha_Rules69 View Post
    That's the swap I'm after. I've never owned an air cooler, so I didn't have that for back round knowledge. Thanks, I appreciate the help. Just need to find an early 250R front end now and a 185S rear fender and I'll be ready to roll.
    The swap Shortline wrote about I've done several times also. Thanks for that information also
    Have too many parts
