Results 1 to 6 of 6
Thread: Jetting help
    861
    Jetting help
    Im at sea level and have a 86 250r with fmf system, uni filter and a set of v force reeds. I cant seam to get it to idle no matter what I do I've replaced the float needle and running 145 main and the stock #42 pilot jet I always have to have my air screw out 2 - 3 turns and the idle turned up all the way. somtimes gas will leak out of the carb bowl over flow. When I cruize at 3rd or 4th gear at 1/3 throttle it surges. Can the float take on gas inside the plastic part? I've checked the float and took it in to the shop in town and he said its good to and the needle will hold 5 psi of air. Thanks
    ]1986 ATC 330R
    Feb 2009
    michigan
    2,387
    your jets are correct your needle should be in the third ring and the mix screw at 2 1/4 turns out.if thats right you should continue to look at the float,gas should not come out the overflow
    1985 ATC 250R
    . Team Red Trike
    861
    Yes that's where I'm at I'm gonna pull the float tomorrow and put it in a container and look for bubbles. Theres not much else it can be Thanks I'll post what I find.
    ]1986 ATC 330R
    Feb 2009
    michigan
    2,387
    clean your float pin and fill hole well,i had a grain of sand or rust in mine and screwed me for awhile till i found it
    1985 ATC 250R
    . Team Red Trike
    861
    I was out sunday and rode both of my 250r"s and both of them run finicky at 1/3 throttle? Place in mt area I talked to said worn slides mabey.
    ]1986 ATC 330R
    861
    Well today I took the R's out its dry today and 75 deg its been muggy and 85+ for the last 2 months. In the 86 250r thats stock I went from a 42 pilot to a 40. It idles fine and the air screw at 1 1/4 turn. It dont do that sputter at all at 1/3 throttle but when I come from a full throttle 6 gear run and down shift it bogs off of idle. I went to a 40 pilot in my ported bike to and it helped alittle. It just dont make sense to me that with a pipe and porting I would have to go leaner. The only thinkg I've found and heard was excessive wear from lots if use??
    ]1986 ATC 330R
