i have a 350x and the kickstart lever has a lot of play in it. when u are riding it falls down into your leg. makes a person mad when u are riding in bumps and it falls down when u are standing up. is there a way to fix it or do they make them yet.
86 350x
85 250sx
84 200m
79 110
you need to replace the ball and spring in the pivot area. also the detent in the knuckle may be worn out. if so you will have to refill with weld and re drill a small detent in it.
