Page 4 of 12 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 46 to 60 of 180
Thread: The 490Z the saga continues... Round 3!
  1. #46
    It appears your cylinder has an iron sleeve, and it would just be overkill to nikasil it. That's probably why they didn't coat it. Did you want it nikasil coated?
    thats probley why they didnt.....good point.. going back they were going to nic the repaird sleeve ,,not this one
  2. #47
    the swingarm Kasy made for me arrived yesterday morning,,,
    Worked into the night
    All the oem bearings and seals ,,oem Rod components,,got a few paychecks sittin on my dresser....
    Attached Thumbnails Attached Thumbnails DSCN1987.jpg   DSCN1998.jpg   DSCN1996.jpg   DSCN1994.jpg   DSCN1997.jpg
  3. #48
    wisconsin
    25
    So what is all done to the motor mod wise? I am assuming that it kicks to the rear as the fenders are cut but is it possible to convert the 490 motor to foreward kick in you experience? BTW that is a SWEET Z!
  4. #49
    Quote Originally Posted by cumminstroker View Post
    never tryed it ..it was easeyer to drag cut the fenders,, not shure you would get the rotation to fire it,, the kickstart ends up below the peg when kicking it.. you would be mashin that kicker into the footbeg every kick..
    The crank has been knurled,Drag ported by dynoport,head has been re cut and the squish band removed,carbon fiber Reeds,..ect.. got a 44mm round slide I was thinkin about throwin on.. by leaning twards the 41.5mm PWK for that chrisp-ness!
  5. #50
    worked on the lights today.. on the left a 490 stator,right a tri-z ,, between the two I got it figured out,, the yz stator plate is identical to the tri z ,,except the ground hole is not threded,, and the stator coil is bigger,,, so what we end up with is all yz stuff on a triz stator plate with a lighting coil!!! Red is hot... oh and my ITP rims.... sitting at 50"! studs installed in the cylinder...
    Attached Thumbnails Attached Thumbnails DSCN2205.jpg   DSCN2207.jpg   DSCN2209.jpg   DSCN2211.jpg   DSCN2213.jpg   DSCN2212.jpg
  6. #51
    Feb 2005
    suffolk,va
    109
    Looks like it is coming along nice! Can't wait to see some action pics.
  7. #52
    Southern MN
    1,875
    Hells yeah. Keep the great pics coming raffa!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
  8. #53
    bigbadktm's Avatar
    bigbadktm is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    San Diego, CA
    437
    love the color of that swingarm
    1985 250R
    FMF pipe and silencer, K&N, 4" extended swingarm
  9. #54
    Jan 2008
    Cleveland Texas
    305
    Are you going to do the squish mod to prevent predetination? Or just run race gas? 490's are awesome engines. Nice build!
    EDIT- I see you got it done, my bad. Should be a beast of a trike, good luck!
    -Fathers 1985 200X
  10. #55
    Quote Originally Posted by kasey200x View Post
    I run race gas ,, and I guess you never saw my head huh?
  11. #56
    jmax857's Avatar
    jmax857 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bancroft canada
    354
    what did you use to paint that cylinder on page 2?
  12. #57
    Quote Originally Posted by jmax857 View Post
    PJ1 Epoxy gloss black,,,you gotta have the paint and the part above 70 degrees...
  13. #58
    Jan 2008
    Cleveland Texas
    305
    oh man... extremely nice.. Wish i had that a few months back!
    -Fathers 1985 200X
  14. #59
    Mar 2004
    North Central Ohio!!
    2,712
    Your bike is looking really nice Bryan. So you threw a shorter swingarm on it then?
    I'd like to know the vibration difference between the Z motor and the 490?
  15. #60
    Quote Originally Posted by Derrick Adams View Post
    Kasey built me a +6 for the dunes,, and the vibration,, is just a little stronger than a tri-z,, I really dont even notice it anymore,, and a new set of fat Oury grips helps,and I got a new seat comeing with new foam..So that should help also.I think the worse vib I ever expearanced was a cr500 in a quad frame..this is not even half as bad.
    I have a +12,+6 and a stock length swingarm for this bike.
