Results 1 to 15 of 15
Thread: '85 Big Red 250es...no 4th gear
    Nov 2009
    Okauchee, WI
    555
    Doesn't seem to go into 4th gear, goes to neutral. I am positive I'm counting the gears correctly. Acts like it kinda wants to go into 4th but it doesn't. Neutral. Anyone else ever encounter this? I was looking at the manual, could it be something with the shift linkage or shift drum? Thanks, Matt.
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Sep 2009
    PA zip 15942
    17
    i have 2 complete botom ends i would sell you a botom end for $50.00 + shipping
    LONG LIVE THE BIG RED 250ES
    Nov 2009
    Okauchee, WI
    555
    Quote Originally Posted by will_15942 View Post
    I'll keep ya in mind, but I'm hoping it's something I can fix semi easily. Gonna have to take off the left case cover and take a look at the shift linkage and drum I guess.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Nov 2009
    Okauchee, WI
    555
    Hey will_15942, how much you think it's goin to cost to ship a lower end to Okauckee, WI zip 53069? Did the bottom end you have work well? I'm hoping I can just just bolt on my upper and run it. Really need this thing for ice fishin. My Big Red 250 es is a '85 if that makes a difference. Thanks, Matt.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Sep 2009
    PA zip 15942
    17
    im thinking $100.00 shipped and bottom end worked good paypal or money order
    Nov 2009
    Okauchee, WI
    555
    I would be all over that, but money is pretty friggin tight right now. When I have an extra hundred bucks I'll be callin to see if ya still got it. How did you remove the driveshaft? Like the manual says? I read if you removed the bolts and stuff it's a pain in the aise to put it back together. Split the cases and all. Thanks, Matt.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Nov 2009
    Okauchee, WI
    555
    I might have some extra money after next weekend. It depeends on if a buddy of mine who I am putting together a 200x for pays me some of the money he owes me. If he does I'll take it fo sho!
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Take off the left cover, inspect all the pins,springs etc etc. The 250SX has a flaw in this area. Why 4th?? I don't know but I count "SL" as 1st so there ought to be 5 gears.
    You may find something loose or snapped especially if it just happened. The tranny is pretty tough until humans touch it
    Nov 2009
    Okauchee, WI
    555
    Last week I took off the levt cover. Pulled the shifter shaft out and the drum and pawls and springs and stuff oh my. Everything was good. Manually shifted the drum through the gears, it would jam stop in neutral metween 3rd and 4th. Wouldn't go any farther and I didn't want to f anything more up by forcing it. A shift fork has to be bent or something. It still works, but no 4th.
    Hey will, I talked to my buddy, he'll have some cash for me next weekend. So if ya can hold on to that bottom end for me, I'll get your info next weekend and I'll send ya a money order.
    It'd be keen to have 4th gear for the ice
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Sep 2009
    PA zip 15942
    17
    i took the moter out of the frame theres no side covers but the clutch and everything is there i have a black bottom end and a aluminum finish bottom end
    Nov 2009
    Okauchee, WI
    555
    I'd be interested in the aluminum finish bottom end. Whan you removed the engine, how did you unhook the driveshaft. Did you pull the boot back and slide it out, or remove the cap with bolts on the engine. Thanks.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Sep 2009
    PA zip 15942
    17
    i just removed the whole engine and the drive shaft came off
    Nov 2009
    Okauchee, WI
    555
    Thanks, that's what I was wanting to hear. I'll talk to my buddy this weekend about the money. I should know either way by monday.
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
    Sep 2009
    PA zip 15942
    17
    cool have a good week end
    Nov 2009
    Okauchee, WI
    555
    pm sent, thanks
    '85 Honda 200X
    '85 Honda 250R
    '82 Honda ATC 70
    BRUP!!!!!!!!
