Results 1 to 11 of 11
Thread: Holley truck avenger carb
    Apr 2009
    Western, CT
    139
    Has any one used one of these carbs? I was out wheeling with my jeep and I cant take the pos edelbrock that is on it any more. The carb is good on the street and mild trails but is awful when I start to go up anyting really steep. I am going to go with a propane set up over the winter but need a good carb for offroad now to hold me over till then.
    COLORADO
    685
    Lowrider Avenger. It can take nasty angles and not starve the engine. Either that or a giant Tillotson
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Apr 2009
    Western, CT
    139
    I looked up the carb and it has the same specs as the truck avenger except it seems to be polished to a chrome look.
    obijuan's Avatar
    obijuan is offline At The Back Of The Pack Arm chair racerFirst time rider
    san antonio texas
    226
    went from a regular 650 holley, truck avenger and tried my JET stage 2 quadrajet and i really appreciate my qjet. seems to run better for longer off camber.
    Sep 2009
    Washington
    553
    I run one on my Flattie, my dad runs one on his, my sister has one on her CJ-5, and Ihave one on my 69 Ford 4x4. They work pretty well...They aren't completely perfect but what carb is?
    2) 1977 Honda ATC90
    2)1985 Tecate
    2005 Banshee LE
    01 Honda 300EX
    74 Suzuki TC100
    66 Honda 305 Scrambler
    83ATC185S is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2007
    Show Low, Arizona
    291
    I put a 670 on my 351w before going EFI. Like jeepermc said they work pretty good,but arent perfect. Hence the EFI
    Sep 2009
    Washington
    553
    I'm working on throwing an injected 5.0 in place of my warmed 289...I ran a 670 on my 289, Sis's CJ has a 670 on a low compression 304 (read: worn out)...Dad's Flattie has a 470 on a mild 283 Chev and my P/U has a mild 410FE with a 670...
    Not injection but better than most carbs out there...
    2) 1977 Honda ATC90
    2)1985 Tecate
    2005 Banshee LE
    01 Honda 300EX
    74 Suzuki TC100
    Apr 2009
    Western, CT
    139
    I ended up ordering one this morning. I guess we will see what happens it only needs to get me through till spring time by then I will have my propane conversion ready to hook up.
    atcrider1's Avatar
    atcrider1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Montrose MI
    400
    anything is better than an edelbrock
    " I gotz the 8-track player mounted to my Oly, it's pretty sweet for trail side dance parties....."
    -Uller God
    WilliamJ's Avatar
    WilliamJ is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2010
    Poole, England
    157
    Jeepermc
    In a word - Weber! Best carbs ever made.
    Apr 2009
    Western, CT
    139
    I had a problem getting my idle correct but I think it is all fixed now. I must say that after I put it on I ran down the street to a quarry near my house and I ran it up some sick climbs with out a hitch. Stuff I had a hard time with before due to the old carb.
