hi my 200x is a wicked tail dragger, now i know that all of them are, but i have seen a few raised up a bit. is there any way that i can raise mine up? like raising the shock, a shock from something else that will bolt on? anything will help
no more toysmaybe buy a 250r?
past:
86 250r
88 quadracer
83 200x
Did you already try tightening the shock?
LED obsessed
2015 Yamaha FJ-09
how do you tighten it? add nitrogen? if it is can i just add air or where can i get nitrogen..
past:
86 250r
88 quadracer
83 200x
The bottom of your shock bolts to a "dogbone" flip the dog bone upside down, you will gain some that way, also on the top of the shock spring there are two 1/8 inch thick adjustment "nuts" they look like oversized washers, loosen the top one then tighten the bottom one, this should give you some more height, if it is still spongy then you need to have your shock rebuilt. Hope that helps, oh by the way a special tool is used to adjusting that but in a pinch a punch andhave done the trick for me
On an 83 he won't have the dogbone. The shock mounts right to the swinger. You could switch to the 84-85 swinger and do it.
Rob
That's right, good call. I forgot that, my bad. You can still adjust the shock though!
well, i just went out to adjust the nuts, and i found out that both are already at the bottom. how do i add nitrogen or whatever to raise it? can i just add air?
past:
86 250r
88 quadracer
83 200x
u can always get and 84 85 swing arm and then put a 350x rear shock under it and 350x front end that would sure raise it up
1985 200X
66mm H&S Piston
Little Bit Bigger Cam
Bassani Exhaust
1985 350X With Bassani Exhaust
1983 Honda 200E (PARTING OUT!!!!)
1985 Yamaha Tri-Zinger
My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
i jusr recently bought a 84 swinger for my 83 x.... a 350x shock will bolt right up>?
No, you cannot add air. The shock was designed for nitrogen, and if you add air, the shock will be ruined. Special tools are neccessary for rebuilding the shock, and removing the cap on the canister to gain access to the filler valve. Does the shock feel bouncy if you jump on it? If so, time for a rebuild. It will need new seals, and re-charge. If the shock is tightned all the way, it should be STIFF, even for a 200+ pound guy, and would not bounce if the seal is good. Sometimes the best bet is to go on ebay, and a decent non blown one can usually be had for around 20-30$.
The 350x shock mod requires some fabrication. You have to modify the rear dog bone, or make a custom mount on the 83. The front end mod requires the 350x tripples, forks, cutting the turn stop, and basically all the other 350x components.
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
