I'm rebuilding a 1984 ATC with Lifan 140cc motor. Issue I'm having now is getting the carb/instake to bolt up correctly so that the top of the carb will clear the gas tank and carb won't hit the cyclinder head on the motor. Does someone make a intake that bolts up to the Lifan 140 that will allow the carb to clear the ATC70 gas tank and motor? I know that there has been a lot of people installing a Lifan 140 in their ATC70 so I would greatly appreciate it if you could share with me how you made it work. Thanks!
