It looks like an 82 yt175. Whatever you do, don't use synthetic oil in it. Alot of the old type clutch fibers don't work well with synthetic oil. If you look on the right side of the engine, you will see where to add the engine oil. To the front of that about an inch or 2 and slightly below, you will see a bolt, that is the level bolt for your oil. You pull the bolt or plug out and fill the oil level till it runs out of there. Also try and do a search as there are several threads on here about what the different lines are for on the carb and the oil pump. Premix ratio can be slightly different depending on the maker of the oil. Check the back of the bottle for recommendations. Use a 2 cycle oil for motorcycles. Some people try and use weed wacker 2 stroke oil and I really wouldn't recommend it. Try spraying some wd40, or kroil or pb blaster down the choke cable from the top and that should help alot. It might take several days of spraying to get it all the way down the cable. A new spark plug would be highly recommended. Make sure you lubricate your brake cables as well. You have to open up the right side of your engine to adjust your clutch. I also highly recommend downloading a shop manual or picking one up, they are invaluable. Make sure to run with the airbox lid on or you'll get a real lean condition and the trike will try and death rev on you. If it death revs, super high rev, you will have to pull the spark plug wire. Have fun with your new project. Try and do some searches for yt175 info, but beware, the search feature on here sucks.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
