Results 1 to 10 of 10
Thread: 38mm mikuni 2stroke carb. whos running it?
    Sep 2003
    138
    what is everyone running for jetting in there 38mm mikuni carb (to whoever has one) in there 250r tri-z tecate banshee what ever? iam running a 380 main, and a 55 pilot. seems alittle rich, but i like it that way
    Apr 2003
    141
    carb
    im runnin a 38 mikuni with a clamp on k&n, i dont know what the jetting is but its big, i thought that i was just being dumb or i was doing something wrong, but everybody i talk to says that it needs the really fat jets, and it runs great
    Leaks, Leaks, Leaks! Why does it always have to leak!http://www.3wheelerworldforums.com/viewtopic.php?t=11559
    May 2002
    Texas
    2,670
    Hey badtriz, I've got a 38mm Mikuni Flat Slide laying around that I was running on my 84 KXT. I'd like to get it onto my Tri-Z. What intake boot did you get? I've heard you need one from an IT250. Just curious what you ended up using.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    I have a 38mm FlatSlide on my 86 Tecate and have run anything from a 280 to a 300 Main Jet. I have never run bigger than a 300. This is on a portd, piped bike.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    Apr 2003
    141
    boot
    all i did to get the carb to fit was to take a blow dryer and heat the boot up for a couple of minutes and then just shove it on. it takes a little bit, but it will go with no ripping and after its been on for awhile, it goes on like a stock one would
    Sep 2003
    138
    Quote Originally Posted by Curtis-Tecate3
    Curtis.
    because of draft right? i'am running a 390, and iam thinking of going down to a 320. but was really iffy on it.
    352
    Monoxide, Please also remenber that I am in S. Florida. I dont know where you are located (Altitude) but your jetting will be different from mine.
    Curtis.
    Sep 2003
    138
    Curtis.
    yes iam aware of that. but it won't very too much. i believe we're pretty close. iam 750 and i don't ride any closer to sea level. i think i'll try a 320, iam just scared to blow it up :shock:
    Washingtons Crossing, Pa.
    2,977
    I had a Mic 38mmTMX flatslider on my 400L, great carb ..... I think I ran a 340 main - can't remember if that was in the winter or not.
    Sep 2003
    138
    mine runs fine on top end with the 390 in it, but it smokes pretty good. the other day i took the reeds out and the crank was right full of fuel, and it wouldn't start.
