Results 1 to 13 of 13
Thread: Fixing shift shaft splines
    OK
    5,450
    Has anyone had any lucky fixing the splines on the shift shaft. The splines where the shifter goes on are all kinds of buggered up. Are there any ways to fix the splines without replacing the shifter shaft?
    I think I know the answer, but figured I would ask if someone came up with something I haven't thought of.
    Thanks in advance..
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Feb 2009
    michigan
    2,387
    you do know the answer to this.you can weld the shifter on for a quick fix but youll have to grind them back off if you need to get in the motor
    1985 ATC 250R
    . Team Red Trike
    OK
    5,450
    Yeah, I know.. I thought about taking a fine file to the splines to "reshape them". It would probably be more trouble than it would be worth.
    Rides:
    My feedback thread
    Feb 2009
    michigan
    2,387
    i have also drilled a hole through the shifter and shaft then ran a nail through to hold,it worked too
    1985 ATC 250R
    . Team Red Trike
    Apr 2002
    s.w. michigan
    6,498
    Doug, I was with Howdy when he done this type of emergency field repair on trikeholics machine at one of those trikefest meets (can't remember the year) and it held up until he replaced the shift shaft its self, some thing like a year and a half later (and it was still working fine too)
    http://www.3wheelerworld.com/showthr...t+shaft+repair
    What was done was the pinch gap on the shifter was filed open (and probably forced open some too), a strip of alu (from a pop can) as wide as the spline area of the clamping part of the shifter was rolled around the stripped out shift shaft splines and the shifter re-installed and tightened down.
    Perhaps get you by until winter tear down,,,,
    Nov 2006
    southern oregon
    2,338
    shifter shafts are easy to replace... just tack weld it til you have a good reason to pull the clutch cover
    2-stroke lover
    OK
    5,450
    I recently bought a shifter for Kendra's motor. When I went to put it on the splines on the bottom of the shift shaft are fubar'd. Looks like the motor I bought was laid on the shifter shaft and drug across concrete or something. It's just the bottom of the splines. But it's enough that the shifter won't go on. Can you replace the shifter shaft without splitting the cases?
    Rides:
    My feedback thread
    Nov 2009
    Okauchee, WI
    555
    According to the manual you can. Pull the left and right crankcase covers to gain access. Once off the gearshift spindle should pull out ( hehe pull out?).
    '85 Honda 200X
    '85 Honda Big Red 250es
    '85 Honda 250R
    '82 Honda ATC 70
    '87 LT500R Quadzilla
    BRUP!!!!!!!!
    Nov 2006
    southern oregon
    2,338
    if there is still good spines I would try filing the bad ones so the shifter will fit... I though you were trying to fix stripped splines.. and yes you can replace the shift shaft without splitting cases, just have to pull the clutch cover..
    2-stroke lover
    Some you pull the left cover, some the right and then other parts may have to come off, but no splitting cases; Maybe a clutch with a special pronged socket though.....
    Sep 2008
    845 New York
    2,302
    is it just me or does this link not work? i was just about to fix my shift shaft and saw this thread
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    TrickShot's Avatar
    TrickShot is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2010
    Delaware County New York
    358
    Quote Originally Posted by code200k View Post
    I didn't work for me as well, thought it was just cause I have a low post count, guess not though.
    Mar 2005
    overton, PA
    5,257
    i have drilled a small 1/8th hole on the endof the shaft with 1/2 the hole on the shifter and 1/2 on the shaft and run a small cap screw into the hole and i have done it a few times with great results and its still removeable.
