Thread: Yamaha RD60 help needed
    Aug 2010
    Buffalo
    Hi
    Anyone know about these little bikes?
    I have a 1975 RD60B that has the cylinder all scored up and will require machining. The bore should clean up to between 42.5 and 43mm.
    I've seen 1st oversize (.25) and 2nd oversize (.5) pistons for sale but they never say what the pistons measure to. What was the standard measured piston for this bike? What size should I look for/be able to find?
    I haven't seen anything wiseco for an RD60.
    if I can't find a piston, would the jug from an RD125 or GT80 fit on an RD60? Did those bikes share any parts with the RD60?
    Thanks!
    Baltimore, MD
    6,088
    You should talk to bandito90 on here, Timmy. He has an rd60 and the story on it is pretty amazing. We've been kicking around the idea for a gt80 top end. I have an aftermarket gt80 pipe and aftermarket gt80 large intake I keep trying to talk him into putting on. I'll try and find the stock piston size. There is a thread on here about his "POS 60" that tells more about his bike. I think the bike is posessed. If you would have seen how it looked when he bought it, well, it's pretty hard to describe. It had been layed down and the instrument cluster had been busted up pretty bad. Well, we just had to play around and got out the point file and did a little manual labor and set the points and added a little premix and it fired up! And one or two of the bulbs on the instruments actually lit up. Scary really. And the bike had the handlebars turned upside down to give it that "cafe racer" look. And the seat was a piece of plywood with a small cushion on it. And it had a front fairing and chin spoiler on it at one time that were also all busted up. The bike has come along way since then. Best of luck with your new project.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    bandito90's Avatar
    bandito90 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    284
    Scmill,I would need to look at my shop manual to get get all the bore and stroke stuff.But I have been told by a few people that the gt/mx top end bolts up.I have one and have not tried it.This motor has been used in a variety of bikes.the basic bottom end was used in gt/mx 80,early yz80,yz50 and ysr50.I believe the gt80's were a speed vs the 5 speed in the yz motors.the gt80 and rd60 use a different stroke.I've read that the gt80 crank is what's used to stroke the ysr motor.I can tell you the reed blocks on the gt80 and rd60 are different.I would assume you could put a ysr top end on and have a better reed and carb setup vs therd60.Also I think the yz50 cylinder has better ports than the ysr .And it's alloy . Hope this helps.I'm far from an expert.But these are some of the things I know from researching on the net and talking to others.Here is a link to a more ysr oriented page. http://webpages.charter.net/jpcycles/ysrracing/faq.htm
    1978 bandito framed atc90
    1984 YT60
    1974 rd60
    2002 Buell Blast
    1984 Honda xr100 project in the trunk of my car.
    1964 honda C100
    1981 Honda Hobbit
    1984 Yamahopper
    Dec 2007
    Quebec,Canada
    1,014
    Pretty sure a yamaha JT1 mini enduro 60 use the same cylinder
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
