Thread: New to site
    Texaskev is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2010
    Georgetown, Texas
    169
    New to site
    Hey everyone. New to site, but not to trikes.
    I want to see if anyone can help me here. Got an '81 200 with bent forks, and no fender. Will any of the later 200 e's or m's interchange? (forks) I know the fenders are matched to the forks. I also know that the front brake hub is different on the 200 and the 200 E. I would like to replace the original fork and fender, or upgrade the whole assembly from the neck down. Any ideas? Also the headlight is very dim on the '81 200. New light, and when I hook it up t oa battery it is bright. I know that with this system, it won't be as bright at idle, but even when the R's come up, it doesn't get as bright as it should. What do ya'll think? Stator weak maybe?
    Thnaks for the help.
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    not sure but i think a 200x front will work so u could have suspension up front?? hopefully someone will clear this up
    Apr 2010
    massachusetts
    135
    im not sure if the tripples will line up to the frame the bearings might be different sizes. but you could measure, if there the same size, do it up
    no more toys maybe buy a 250r?
    past:
    86 250r
    88 quadracer
    83 200x
    Aug 2010
    Georgetown, Texas
    169
    Not sure about the x front end. Anyone know if the Big Red front end will work? Any ideas on the weak headlight? Thanks for the help guys.
    Jul 2008
    MD
    911
    The 200x I don't think work... the 185s 200 and 200s all interchange though.
    The 350x, 200x, and 250sx I know use different bearings and will not fit the 1981
