Results 1 to 4 of 4
Thread: 250r swing arm
    tulsa area
    5
    250r swing arm
    can anyone tell me the diff. between a 85 250r atc and a 250r atv.all i can find is atv swingarms, i need to stretch mine out badly.
    Apr 2009
    Western, CT
    139
    The 85 swing arm uses a different bearing carrier, brake mount, and axle.
    Blossvale NY
    4,563
    you can use that swingarm if you use the 86 and later aforementioned parts....
    YJ350: was the caliper itself different as well?
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Apr 2009
    Western, CT
    139
    Dont quote me on it but I do believe they are the same caliper just a different mount. The 85 has a brace off the caliper mount that bolts up to the swing arm and the 86 has a bushing on the swing arm that the caliper stay fits over.
