what order should i mod in?
hey guys, im just wondering whhen i haveat order i shld do mods in. im sure mostly its personal preference,but i want a UNI or K&N airfilter, dunno which is better. a cobra or DG exhaust, and also a jet kit. i just dont know what order to get them in when i have the cash. any other mods btw?
what kind of trike is this for?
i'd get the jets first so you have them on hand when you change the exhaust and filter.exhaust is your biggest ticket item so youll probably get that last.
1985 ATC 250R
Team Red Trike
thanks its for a 1984 ytm200e.does anyone know the top speed stock because i want to compare before and after.
its probabl;y not going to raise your top speed much. what it might do is give you more power so that you can get to that top speed faster.
buy them in whatever order you want.. but install them all at the same time.. the pipe and filter will change the jetting... And K&N filters have no place on dirt bound machine
2-stroke lover
yeah, in my opinion go with the UNI filter and the DG pipe.
Cobra's are cheap loud crap that will rust out and fall apart within a year. you might be able to get one to last a while if you paint it constantly. DGs just seem better made.
oh good, i dont want to go through the hassle of painting it.i have enough on my plate as it is.
even a DG pipe will need some maintenance. finding an aluminum pipe would be the way to go if you can find one, they wont be cheap either. I know no one makes an aluminum pipe for my 110 anymore so finding might be hard
//ArrowChat Integreation Code
