Thread: 86 tecate thumb throttle options - what works?
    Mar 2003
    NJ
    911
    i would like to get some thumb throttles for the 86 tecate and would like to know what are the options. does any thumb throttle work? i know i read that someone used a yfz450 thumb throttle. anyone using anything else? do i then need to buy the throttle cable for the thumb throttle i purchase or is the tecate cable the correct one to use? was wondering if i could pick up some kawasaki model thumb throttles such as Bayou...
    same person with the yfz450 thumb throttle had a yfz450 front master...which makes sense perfect fitment at the handlebar...or is that not an issue to consider. such that all thumb throttles will basically be ok against any front lever assembly?
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    Sep 2005
    MICHIGAN
    2,027
    I think thumb throttles are pretty generic and that's why not many aftermarket ones are made.
    But, I had some kinda Yamaha one on mine and I think it was for an old 4 stroke like a Moto 4 or something cause it was jerry rigged were the cable entered the throttle housing due to the opening being bigger than the cable and screw thread. I had to go back to a twist since I sold my LT250R one which would have worked.
    86 T3
    84 T3
    86 KX250
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    I've got a couple of thumb throttles if you're interested. I "think" they're from a Kawasaki of some sort.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    Nov 2006
    southern oregon
    2,338
    i used one from a 250r on mine... I like it much better than the terry cable style thumber I bought from moose... i just used the cable that came with it, but I was also running a keihin carb
    2-stroke lover
