Results 1 to 7 of 7
Thread: 350x connecting rod play
    texas
    567
    maybe the real question is "is there to much play" ive never went through an atv engine like this before so before i jump out and spend the money or even split cases i thought i would get some advice from the experts. what im concerned about is the wobble you se in the video "top goes left bottom goes right"
    or is that going to be fine once i get the new cylinder back on it.
    http://www.youtube.com/watch?v=fMK0VBspJIs
    Aug 2007
    Moab, UT
    1,807
    Does it have play straight up and down? How many thousandths of an inch feeler gauge can you fit between the rod and the crank?
    texas
    567
    there is no up and down play but a connecting rod should only be able to move left and right with no wobble correct?
    WNY
    517
    Looks normal to me. Once the cylinder is bolted on there will be no side-side play.
    85 Big Red 250ES
    01 Scrambler 90 (Sons')
    Past Machines:
    96 Yamaha V-Max 600, 86 200x, 84 200es, 82 70, 82 200, 03 Bombardier DS650, 93 Ski-doo Formula Plus, 87 Ski-doo Stratos, 83 Yamaha XT550, 82 Kawasaki KDX175. 84 Tecate, 86 Tri-Z, 91 CR250.
    texas
    567
    alright thanks. i guess ill just run it as is then.
    Aug 2007
    Moab, UT
    1,807
    Some side to side play is normal. You don't truly know if it is too much or not unless you take a measurement with a feeler gauge and compare it to clearance specs in the book. Please, just do the measurement while you have the topend still off.
    Puggerton, do you have a calibrated eye that can also compensate for video distortion so that you can spec out side to side rod end play? What if he puts money into a fresh topend on that motor and fires it up only to hear bottom end noise? whooops
    WNY
    517
    Yes, my eyes are calibrated. I did have laser eye surgery after all.
    85 Big Red 250ES
    Past Machines:
