Yami TriMoto 175 just wont run right
I've cleaned the carb completely, the gas is new, i've checked everything else I can think of but here is what it does. The acceleration is not smooth it has no torque at low RPM untill it reallystarts reving it seems to sputter and not run right at all but once it revs watch out. Any ideas?
Sounds like the jets are clogged. I think there are 2 jets that should be free flowing with a tiny hole in the middle. Are you sure both of the jets had the holes clear? If the low jet is clogged, things just won't run right until it gets higher rpms.
//ArrowChat Integreation Code
