Results 1 to 3 of 3
Thread: Tri Zinger help...please
    Aug 2010
    Florida
    5
    Can someone please explain how to remove the rear axle nut on a tri zinger. How do you keep the axle from moving while trying to loosen the nut? The actual nut is really torn up as it appears the previous owner had the same problem. Thanks in advance. Robert
    OHIO
    2,857
    Quote Originally Posted by rducati1 View Post
    http://72.52.143.80/~trikes/tri-zing...vicemanual.pdf This may help you.
    Aug 2010
    Florida
    5
    Thank you for the reply. I have the service manual...but it doesn't tell you much in terms of how to remove the nut...I have tried about everything including heating the nut and using vise grips. Looks like I may have to cut the nut off Oh well...looks like some more busted knuckles
