Results 1 to 3 of 3
Thread: Tach to adjust rpm
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    Tach to adjust rpm
    Anybody now where I can get a fairly cheap but accurate tach so I can check the idle rpm on my 185s? The reason for wanting to make sure idle rpm is correct is so I can check the timing.
    I have an 8 cylinder clip on style(its a tach and dwell meter), is there some formula I can use to make it read for a 1 cylinder? Thanks.
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    Sep 2007
    100mi west of Chicago
    3,582
    I got one of those Tiny Tachs and I can use it on all single cylinder engines to check rpms. It was around $50 I think. I originally was trying to find an old bike tach but even beat up ones on eBay went for $20+, and I wasn't sure they would even work.
    Rob
    Feb 2009
    michigan
    2,387
    do it by ear.if you put it in gear and it moves without the throttle than idle is to high.if it stalls than its to low.or have a friend count the revolutions of the motor while the pull start is off.
    1985 ATC 250R
    . Team Red Trike
