KLT250A Electrical
I just got a KLT in to get running. New coil and CDI box. The stator is good, but have no power to switch, no spark, and will not crank. It will crank when jumped on the 2 large posts. The wiring is clean, untampered, and all connections are clean. Would it be the brain box? I've heard these go bad, but never told symptoms of a failed one.
My old KLT did this, but I never got around to changing things out, just sold it.
Any insight would be appreciated,
Thanks.
Also heard somewhere you can use a Chevy HEI coil and bypass all of it, true????
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
